Ok to use a higher amp fuse inline?
lildragon45
Hi so I just picked up a Rockford Fosgate Prime R400-4D. Its 4 x 75 @ 4 ohms Class D. So they recommend having a 40A inline fuse. Would it be ok to run say a 60A or 100A instead? Pros and cons please. Also this what I have readily available at home. But if I should stick to the 40A then I will. Any input will help thanks.
Fuses are made to blow before the amp blows and possibly burns your car down , use what the manufacturers recommend . Also if your fuse is to high for the wire your using it will burn up and not pop the fuse.
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
  • 1 month later...
No absolutely no. The online fuse is a fire protection. If you replace it with a higher amp fuse and the power wire grounds out it will not break before damage is done to your power wires or  worse a fire. Changing to a larger fuse is not going to change the performance of the amp. If you want better performance by feeding more power, look into things like big 3 upgrade or more effective active cooling setups.
  • Who's Online   0 Members, 0 Anonymous, 1089 Guests (See full list)
