Recommend an Amp
RichSsa
Hello gents I’m a newbie here and in need of help. I just purchased a Ssa icon 12 inch sub dual 2ohm. I’m having trouble deciding on which amplifier to buy to push this sub. Any suggestions? I’m still not sure if I’ll run it at 1ohm or 4 ohms. My budget tops out at $500.
Running at either 1 or 4 ohm depends on ur electrical. U got a good alt/battery/wiring go 1 ohm cause it's cheaper to get power at 1 ohm, if u don't have solid electric go for an amp that'll give u power u want at one ohm, wire to 4 and start stiffening up electric and then wire to 1 ohm. Don't wanna wire to 1 ohm and low volt the piss outta ur new amp and hurt either sub or amp or both.
Never really considered the alt and battery. The system is going in my 19 charger scatpack and the alt is 220 amp idk if that’s sufficient or not. The battery although new it’ll lose some juice and I’ll replace it with something better down the road.
I don’t know what would be good with enough watts to run the sub at 4ohm but it’ll probably be to high at 1ohm to run this subwoofer, since it’s only rated at 1250 rms.
Skar audio makes great amps at great prices. No need to break the bank. Use the extra cash for a batt upgrade.
I’ve read pretty good reviews on those. Do those skars put out clean watts? Idk exactly what that means 🤔  but there’s some reviews where they say they don’t. Sorry for all the questions, I’m just looking to buy once even if it’s a lil bit more money. How about the sk series?
Why didn't you just buy an SSA Amplifier to go with the SSA Sub ??? Mark and Aaron is very knowledgeable and easy to work with ...
Only options I saw on their website for a SSA amplifier was a 500w 2 channel, 600w 4 channel and a 2200w mono amp. I felt like none of those would work for my application. I tried contacting them with no success. I’m leaning towards a Skar rp1500 amplifier right now.
  • Who's Online   0 Members, 0 Anonymous, 1602 Guests (See full list)
