Jl audio 13.5 W7 1.5 ohm
I have a question I just got a pair of 13.5 jl audio W7s 1.5 DVC I’m going to be using a rockford T2500 if I wire the subs down to 1.5 ohms to each Channel will I be okay?
or can I bridge them?
or what’s the best way to wire them I’ve never used the T2500 so I don’t even know if it’s bridgeable
I’m pretty new to this ohm stuff
thanks in advance
Your final ohm load will be 3 ohms so wattage will be between 2 & 4 ohms from the amp.
Watch a video, easy to find. You have to research and learn. Being told and not shown isn't the best way imo
43 minutes ago, CstrokerV said:
He has  2    I.5 dvc he says  So he can get a 1.5 final ohm load
My bad, I stand corrected. Thanks for pointing that out to the OP so he gets it right.
