Box Confusion
ok for two stroker 15s it calls for 4 cu feet tuned at 40 hz
does this have to be per speaker ? or can i put two speakers in one 4cu ft box tuned to 40 hz and be fine ? or will i need 8 cu ft tuned to 40 hz ?
i went here http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
and put in these values in this order.
30
20
21
21
1
4.5
0
i can fit two of these boxes in my trunk. would this be ideal?? also ports would be facing up vented into the cab via vent holes. speaker facing the trunk. port against the back seat. facing up
and i under stand that i need to compensate for space taken up by the speaker.
is .443 of a cubic foot enough for compensation or would i need a full square foot or so ?
Edited by cerwinvega
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
well if i put the sub opposite of the port instead of next to the port will this change anything ? aka magnet facing port instead of magnet parrallell to the port.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
i wouldnt think it'd made too much of a difference. not 100% sure tho. you do want to keep it as far away from the port opening as possible tho. and as far as i know... your .443 estimate for sub displacement is a safe estimate
thanks for your reply...
anyone else?
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
Subs back ports up is fine.
4cuft per chamber of 8cuft common (recommend separate personally)
brace brace brace.
Some possible solutions to fitting a box that big in a trunk is 1) building two separate 4cuft boxes and put them in 1 at a time. 2) build in the trunk.
-Drew
uhoh_45 said:
brace brace brace.
-Drew
so where would i brace ? under the speaker ?
i plan on using 1 inch thick wood along with puddling all the corners.
btw i cant stop staring at your avatar.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
That's 4 cubes each sub and I have put 15's in a 2 cube box 4 total with displacement this is an spl set up burbed a 152.2 and bass raced a 49.9 but about the 100th time that's a guess the speakers blew so ya 4 cubes each
its incomplete, but a while ago i did THIS. Read through there and do as much as you can lol 8cuft is big, double baffle the front cross with 2x4s or threaded rod and but angles in all the corners... blah blah blah ^_^
-Drew
see these are gonna be mainly use for listening to music and maybe some showing off.. nothing competition.
but id like to have the spl if i need it.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
  • Who's Online   1 Member, 0 Anonymous, 1325 Guests (See full list)
