jizzybizzy Posted May 14, 2008 Report Posted May 14, 2008 so whomever decided to make the design for saturn did not think of the few people who are going to put a system in the trunk.... the license plate in directly on the trunk lid...and therefore making the rattle of the rattle of the plate unbearable.... is there anything to fix the license plate rattle? i would it down... but there is only two holes for the plate... which is also dumb...but im just looking for something to kill the clanking of the plate... i used to have a sponge like object inbetween... but that fell out somewhere... you ain't been bizzy til you've been wit jizzy. Vehicle:: 2005 Saturn Ion Headunit:: Jensen 9312HD Speakers:: RE SE Coaxials Subwoofer(s):: (2) 15" RE SEs Amplifier(s):: Audiopipe AP1500.1D Audiopipe AP1504 Enclosure:: Sealed Wire: KNU KONCEPTZ 1/0 Battery:: Kinetik HC600
KWP369 Posted May 14, 2008 Report Posted May 14, 2008 put some sound deadener like hushmatt or second skin or sumthin on the back of your plate then mount your plate to the trunk Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
Aaron813 Posted May 14, 2008 Report Posted May 14, 2008 Ya just screw your plate down in all 4 corners
sully Posted May 15, 2008 Report Posted May 15, 2008 take the plate off and zip tie it to your exhaust tip... JK You can use sound deadener on the back of the plate and don't be afraid to drill into the car to secure the plate down in each corner. It will greatly reduce the rattle. You may also find that it is not only the plate on the trunk lid that is rattling. I have taken Great Stuff expanding foam and sprayed it into the deck lid on many vehicles. Be conservative at first till you get the hang of it. It will apply slight pressure between the inner bracing and the outer sheet metal to reduce flex as well as add some mass for deadening purposes. Warning: it is messy, please cover anything in your trunk you don't want to have to replace and it is a slow process since you have to wait for the foam to finish expanding. IMO very worth the time and it is a minimal expense. 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
Tub Asko Posted May 15, 2008 Report Posted May 15, 2008 link time Facebook Youtube Murdered '07 Silverado
Shyne151 Posted May 15, 2008 Report Posted May 15, 2008 dynamat on back + four screws in corners = problem fixed -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
aquill1 Posted May 21, 2008 Report Posted May 21, 2008 Dynamat actually makes a special plate kit. LINK...
