Charging the Yellow top Optima
I am in no way affiliated with Optima battery, and what follows is factual & based on well documented research.
I have observed that some folks really like the Yellow top, and others have had bad experiences. Generally the users results with the yellow top optima are directly related to the charging voltage range of the system it is connected to.
The Optima Yellow Top is capable of accepting a lot of charging currrent, and requires a higher voltage finishing charge for maximum life. They can actually be charged at voltages over 16 volts, and require higher voltages as they get older.
Overcharging the yellow top may not result in damage, and can actually extend it's life considerably if done properly.
Some really smart folks at the National Renewable Energy Laboratory (NREL) in Golden, CO spent a whole pile of your tax dollars to scientifically prove this.
They repeatedly discharged test batteries to below 10.5 volts - effectively "dead". They then recharged them to full charge, and added a finishing "overcharge" at elevated voltage. They weighed each battery, observed them with infra-red cameras, etc.
They did this over & over. 356 times on a single battery in fact. A lot of testing. Then they hooked up a bank of 24 yellow top optimas, and started again. Beat them down to 10.5 volts, and then overcharged them. This time they went for 700 charge / discharge cycles. Let me say that again. Seven Hundred Cycles.
The results.
With all of that beating, no cells "dried out". They still weigh within a few grams of the inital weight.
After all of the testing, 21 of the 24 batteries still had resting voltages over 13 volts.
Cycle life was pretty much doubled, by raising the charging voltage.
So, if you have had a bad experience with the Optima Yelow top, take a look at your charging voltage & curve. I have found sometimes that simply putting a "tired" yellow top on the power supply overnight @16 volts will bring it back to life.
For those of you that want to read the whole report, from the govt. website:
NREL White paper on Optima batteries
'Link
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
My yellow top is brand new, and look whats happened i think its spiked my ECU and fried it when i put a fuse in for the ECU it just blows it. I put my car on Diagnostic and the vag-com says Fault code - 'System High Voltage' Think i might just put it in the trash and just get a kinetik and now a new ECU.
Edited by polochris
KICKER Livin' Loud
So what's your voltage?
Thanks MLA for the post. I'll be getting a module for my Explorer soon.
hell if you are going to trash the yellow top lol send it to me ill pay for the shiping
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
Damn it!!! I was gonna post that!!! <_<
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
It sounds like you have something funky going on for sure. The battery dosen't produce higher voltage it only accepts it. It will have higher cca's which may cause an issuse. Your alternator Gives your battery the voltage reading and the battery can't produce its own voltage. You may have something arching, shorting out or loose terminals. I would check these first before chucking the batt for sure. Alternator spikes would be more of a problem I would think.
Kinetic is good too !!! :rolleyes:
Brad aka (link) may be able explain or correct my jiberish. :wacko:
MLA
missinglinkaudio
Interesting read. I've never had any luck with them in any of my cars, system or not. I guess I'm not an Optima person :lol:
They don't last long if their under charged for realz. Most voltage now days(2000ish) keep them about 80% full they don't even get a chance. The smart guy who bench charges them first won't have as many problems.
MLA
missinglinkaudio
Well if the OBD still works, your ECU may still be ok.
Let's start with the basic information - Year / Make / Model / Engine ???
Second, which fuse is blowing?
'Link
missinglinkaudio
  • Who's Online   0 Members, 1 Anonymous, 4387 Guests (See full list)
