What’s up all I have a 2018 f150. I just put a mechman 370 alternator in. Now my charging system light is on and my lights are flickering. I put it in the same way I took it out. Does anyone know if there’s something special I have to do or any help. Thanks
Yea but I even tried to disconnect it. This is driving me nuts. According to mechman it was the belt because I needed a slightly smaller one but that’s not working. I disconnect the battery so I’m assuming the alternator is fine because it didn’t stop running. Also I had my capacitor connected just to watch the voltage. And it goes up and down from 13-15 constantly
How is it grounded? A member was in here with a Silverado, but having the same problems. He got better grounds and isn't having voltage or light flickering problems anymore. I know you hooked it up the same way you disconnected it, but it is considerably more amperage.
I would up that to 1/0 gauge. Is the battery also grounded to the engine block?
Hey brother, so yeah I was having a similar issue. Im not to familiar with Ford trucks but my issue was my ground as @Dafaseles mentioned. Both of our trucks come with a RVC sensor that pretty much monitors the grounds on the vehicle. However, im not too sure if your Ford has that but if it does and its a system where your new ground cables have to run through, then heres is what i did. 1/0 gauge cables all around btw. Put your new ground on the battery, then pull it through that sensor (if your truck has it) and run it all the way to the alternator casing. Mechman has a spot on its case where you put the grounds. After that, run another 1/0 power wire from the charging post on the alt to the positive on your battery. See if that does the trick. Now i would like to mention, my trucks flickering didnt go away completely but it stopped doing every 2 seconds and now its like every 10min or so. I left my truck running all day just to see if there is going to be a big issue and it seems like it runs fine. So im guessing its normal on these new trucks. As far as voltage, its not jumping around like before. Once i start the truck, it will be around 15 volts and it will dip to around 13.5 volts which is stable there.
Thanks for the info. My truck has this Ring sensor crap that’s on the negative wire by the battery if that’s the same thing you are talking about then I’ll try it and let you know. I appreciate the help. My voltage is jumping from 13-14.2 constantly and I get a winding noise when accelerating. I’ll let you know the outcome
I’m plan on it. Just waiting for some wire to get in. Ummmm I didn’t ground it there so I’m gonna say no. But maybe I’ll get to that too
Yup that ring is an absolute PITA, please lmk. i want to help as much as i can
  • Who's Online   0 Members, 0 Anonymous, 869 Guests (See full list)
