Ok how do i make this fit
i only have 31 inches across and I ordered an fi sp4 v2.1 18 and i found a 10 inch aero from big a$$ ports and the port has a 15.25 inch flare.  How can i make this fit?   Its going in a 2019 nissan versa sv sedan with a taramps smart 3k.  Im building the box in the trunk and am going to seal off the front to keep the pressure in the cab.
I think i figured it out.  I can make the port stick out of the box some and have the flare go over the subwoofer a bit.  Do you think the port would break from the subwoofers impact?  Or i can build the box further out of the trunk to where i wouldnt be able to put the back seats back up.
One 10” aero port isn’t enough port area since you have to make that enclosure big, 2 8” aero ports would be the way to go on a single 18” enclosure if 7-8 cubic foot net volume. But if 5-6 cubic foot net volume then that single 10” aero port is a better port area.
:guido:
  • Who's Online   1 Member, 0 Anonymous, 638 Guests (See full list)
