Mattc43 Posted August 9, 2021 Author Report Posted August 9, 2021 2 minutes ago, Dafaseles said: I'm not trying to be rude bro. But, I could be wrong, but what it sounds like is you don't know how to set your gains properly. There's nothing to be ashamed of at all. And I hope I don't come off as rude or condescending. That's not my goal at all. I just want you to have a loud system and for it to be safe for you and the equipment. And for you to wow your friends with the car audio knowledge Not a problem man! It's ok. If setting your gains by ear is not right then I am definitely not doing it right. I just did not want to spend the money on an o scope (I think that's the tool needed to set gains, correct me if I'm wrong) and my process has seemed to work ok for my low power system
Dafaseles Posted August 9, 2021 Report Posted August 9, 2021 1 hour ago, Mattc43 said: Not a problem man! It's ok. If setting your gains by ear is not right then I am definitely not doing it right. I just did not want to spend the money on an o scope (I think that's the tool needed to set gains, correct me if I'm wrong) and my process has seemed to work ok for my low power system I sent you a DM. 2011 Chevy Silverado under construction My build log here. Check it out!
Never Enough Bass Posted August 15, 2021 Report Posted August 15, 2021 U don't have to spend money on a o scope you can just use a dmm if you brush up on some research 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
