Both Batts in the trunk
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
No battery up under the hood
06 Charger
Pioneer double din
Xs power d3400
1 hour ago, Never Enough Bass said:
Mines like the second pic
Ok. When you where talking about it, it sounded like you only had 1 fuse spot between your batteries. My bad dude
Yea only 1 between batteries. Its alt 2 power wires 2 grounds to chassis the 2 power wires go to a fuse under the hood then through the firewall all the way to the trunk to first batt then to a fuse the wire between Batts is only like 3ft then the second batt to a fuse then amp
06 Charger
Pioneer double din
Xs power d3400
When I get a chance I'll take a pic I have to take my subs out 2 show u
06 Charger
Pioneer double din
Xs power d3400
Naw, you don't have to go through all that trouble. You explained it well. I just misinterpreted what you said the first time you where talking about your fusing.
Am I good how I got it fused
06 Charger
Pioneer double din
Xs power d3400
So singer just emailed me and he says they only have a 250a alt that fits my car
06 Charger
Pioneer double din
Xs power d3400
Try Brand X or Autotech- engineering and see if they can make you a bigger one
