I just installed all my stuff upgraded the amp and added a battery but when I shut everything down I get a little pop noise out of the subs can anyone explain this to me
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
Yea all good grounds both battery's are on there own factory location sanded down with a wire wheel post back of nut got it all and the amp is grounded to the seat belt bolt sanded down didn't do this with the old amp I had only thing I added was the amp and a second battery and wires to the battery
06 Charger
Pioneer double din
Xs power d3400
You could try grounding the amp to the battery. When you upgraded the amplifier, maybe that seat belt ground isn't sufficient enough for the new amplifier.
06 Charger
Pioneer double din
Xs power d3400
So I'll move the ground then to the battery
06 Charger
Pioneer double din
Xs power d3400
If you do that, I would add another ground for that battery as well. Hook it up and try it, and if you still have the same issue, or you see your voltage becoming not as stable as it was, at another battery ground
Yea I'm just gonna have to figure something out or what if I get a dual 0 gauge adapter and just add another ground to the amp would that work
06 Charger
Pioneer double din
Xs power d3400
If you do that, I wouldn't put the new ground in that seat belt bolt. Someplace else, as close as possible
  • Who's Online   0 Members, 0 Anonymous, 597 Guests (See full list)
