My design
Would this box work or can anybody help fix it
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
It won't let me put the port in the middle
06 Charger
Pioneer double din
Xs power d3400
Sia 3500 at 1 ohm so before rise 3500 or more
06 Charger
Pioneer double din
Xs power d3400
I'll be double baffling the face
06 Charger
Pioneer double din
Xs power d3400
My suggestion would be to use more port area.  Ideally I'd like to see a minimum of 75 sq in of port area based on the amount of power you are going to be running.  At 52 sq in you will likely have significant port compression and port noise.  Port compression can eat up half your power pretty easily, so it not something you want to have if you can avoid it.
Builds:
Ok so more port area I was just going with the recommendations of the subs
06 Charger
Pioneer double din
Xs power d3400
Yeah, for whatever reasons, a lot of manufacturers recommend less than optimal port area for their subs.  Adding more port area in your situation will certainly be beneficial though.
Builds:
Ok so what if I went aero port instead of a slot port
06 Charger
Pioneer double din
Xs power d3400
  • Who's Online   1 Member, 0 Anonymous, 1615 Guests (See full list)
