isaacxapo Posted October 29, 2021 Report Posted October 29, 2021 First post hopefully y’all can help me… so i installed a system in my 2013 ram 1500 about a year ago now first time setting up a system using a factory radio head 8.4inch(no factory amp) i used the AP4-CH41 R.2 from AmpPro i’m a newbie and i set it up kinda rough looking, so yesterday i had some time and disconnected everything and made it look nice. cleaned up the sloppy wiring i did from before.. however whenever i did this i connected everything back up(to exactly how it was) and my Bass is not even close to what it was before I didn’t adjust the settings on my amp or anything like that but it’s noticeably weaker .. i started youtubing everything about amps tried a few little things and i can not get it back to what it used to sound at all .. can any of you please help me figure this out or suggest things to try? Thanks it’ll be much appreciated
Never Enough Bass Posted October 29, 2021 Report Posted October 29, 2021 Re check connections 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
Dafaseles Posted October 29, 2021 Report Posted October 29, 2021 Yeah dude, sounds like when you reconnected everything, something is loose or not getting the best connection. Just to hopefully save you some time, first check the settings on the head unit and make sure nothing got changed to some weird configuration. It's most likely not the case, but still worth checking. Next, if you get an RCA jack to some kind of portable source (a phone or an ipod or something) and connect it straight to the amp, bypassing the head unit and LOC, see if the bass goes back to normal. If it does, I'd try changing out your RCA's from the LOC to the amp first (maybe they got damaged). Then, if that didn't work, something isn't right after you reconnected everything. 2011 Chevy Silverado under construction My build log here. Check it out!
MrSkippyJ Posted October 29, 2021 Report Posted October 29, 2021 It could be a lot of things. I like the idea of running something directly to the amp to see if the issue goes away. If it doesn't go away, my guess is that polarity is off somewhere. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Never Enough Bass Posted October 29, 2021 Report Posted October 29, 2021 24 minutes ago, MrSkippyJ said: It could be a lot of things. I like the idea of running something directly to the amp to see if the issue goes away. If it doesn't go away, my guess is that polarity is off somewhere. If polarity is off you can just check that with a 9v battery 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
isaacxapo Posted October 29, 2021 Author Report Posted October 29, 2021 I got it guys my polarity on my subs were off… I appreciate every single one of you who took time to reply and give your insight, Thanks much appreciated
