Marchant89 Posted November 19, 2021 Report Posted November 19, 2021 So what’s the pros and cons of stiff vs loose suspension? I have 3 15” Fi with loose suspension but thinking about reconing to change load. I don’t compete but always ran loose and I’m trying to hit 150+ I ran 2 at .5 clamped around 4500 watts or so but they got stanky would stiff help handle the power if I’m in between max and rms?
Never Enough Bass Posted November 20, 2021 Report Posted November 20, 2021 Max watts is a imaginary number but stiff suspension would change your fs 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
Kyblack76 Posted November 22, 2021 Report Posted November 22, 2021 Suspension nor the size of the motor, projects at all to thermal capacity of a coil. I like loose. Loose will have a lower FS. If your competing, want maximum on a tone/burp, and play one frequency, then a tight suspension (when you put a ton of power at a desired frequency, and enclosure tuning, where the driver moves the LEAST) is desired. I prefer a looser, broke in suspension for my daily ground pounders. Another edit- Just a personal post, but, i had Fi sp4s long ago. And adored those drivers. Beat on them for many many seasons. Soft spot in my heart for those drivers. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
