BIG 3 / Alt with no GROUND wire!
Hey everyone, I was attempting the BIG 3 or 4 upgrade recently and realized my alternator does not have a stock ground wire for me to upgrade to 0/1. I've been looking for days on what to do if this happened with no answers anywhere.  2011 Scion Tc.
After googling the alternator for my car I think the ground for it is integrated with the metal around alternator frame itself. And since it's mounted on the engine block no stock ground wire was added.
Should I remove a bolt from the side of the alternator and add a 0/1 ground anyways to the engine block, or is it redundant at that point? Or maybe run it to the negative post on the battery for the hell of it?
Just add the wire to the alternator bracket and ground it to the frame
U can never have enough ground
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
There's no stock wire from the battery negative that runs to the engine block?
There's a ground in there somewhere. There *has* to be
BUT
Don't get hung up on it. You're adding to your factory grounds, not replacing them.
Ideally, if mounting positions allow: your best bet is to attach a ground to one of the mounting bolts on your alt. Barring that - a bigger/sturdier bolt / bracket you have access to that IS NOT part of a gasket. i.e. don't attach a ground to your valve cover.
The battery portion of the car only had negative from the battery to the frame. I upgraded that one already. The alternator doesn't have a ground wire to upgrade. I'll have to add my own wire to one of the Bolts on the bracket. I was confused as I thought all alternators had visible ground wires but I guess it's internal and some how grounded to the bracket and mounted on the engine block.
Like @SnowDriftersaid, there has to be something there already. If the battery negative only goes to the frame, there has to be something grounding the engine block to the frame.
But it's not super important to find it. Just add where you can.
  • Who's Online   0 Members, 0 Anonymous, 1846 Guests (See full list)
