Never Enough Bass Posted April 13, 2022 Report Posted April 13, 2022 I have the sia 3500 it doesn't seem to do what I want maybe it's the Brazilian build idk but it's not for me so going Korean and suggestions 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
stingray72 Posted April 14, 2022 Report Posted April 14, 2022 what is it about the amp you dont like? Also what final impedance do you need?
stingray72 Posted April 14, 2022 Report Posted April 14, 2022 I went with the brazillian amp the taramps smart bass 3 which is stable to .5 ohms and can rise to 4 ohms and still produce 1700 watts but i did have a desire to go korean because some of those can be wired .5 ohms daily and produce more power over all even rising to 4 ohms but they are more expensive at dollars per watt and i wasnt willing to go that far and settled on the above amp at 293 bucks shipped new in box but i understand why you want to make the switch. Ps.... Ive been watching parkers videos on youtube and he has the smd meter that shows real time box rise and power output and i saw that some music rises to 8 ohms when hes wired to 1 ohm on his 12k taramps. Thats a four time rise in impedance i believe. Which means your amp at 8 ohms might put out half the 4 ohm power on a given note. Sundown SIA 3500 Amplifier Rating and Specifications: NUMBER OF CHANNELS: 1CH Power at 1 OHM: 3500W RMS Power at 2 OHM: 3500W RMS Power at 4 OHM: 1750W RMS
Never Enough Bass Posted April 14, 2022 Author Report Posted April 14, 2022 I've had Korean and I've had full bridge amps the full bridge amps don't like any voltage drop at all 1v is a lot 2 those amps and there not really built well not to sure on my ohms after box rise been 2 cold to do anything that involves standing outside lol but I'm wired at 1 ohm box is like 6.88 cu before displacement around 4cu after 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
Never Enough Bass Posted April 14, 2022 Author Report Posted April 14, 2022 1 hour ago, 02Blazer said: Deaf Bonce AAK 4000.1 ... What subs have u had hooked up 2 this and does it live up to what it says it does 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
stingray72 Posted April 14, 2022 Report Posted April 14, 2022 well looks like im going to have to fix that voltage drop from the factory then.....i planned on it anyway.
Never Enough Bass Posted April 14, 2022 Author Report Posted April 14, 2022 I have a 160a alt and like 130ah of battery and when I go from 14.6 to 13.8 my amp sees clipping and this is at volume 34 and I set the gain with a dd-1+ at volume 38 with just 5db of overlap 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
Never Enough Bass Posted April 14, 2022 Author Report Posted April 14, 2022 14 minutes ago, stingray72 said: well looks like im going to have to fix that voltage drop from the factory then.....i planned on it anyway. Don't get me wrong they definitely hit for the price but it could be better quality maybe a little price hike if that's what it would take I know they can do better 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
stingray72 Posted April 14, 2022 Report Posted April 14, 2022 Well now your making me want to use my soundstream dtr 3400 d instead. Arrg
