Crescendo 17k
escottl92
What are you wired to? What's the voltage your running, 12, 14, 16, 18, What's your battery situation, lithium, agm, acid? What's the vehicle? Need way more info, post all specs. Could be a box issue.  With out any info it's a shot in the dark.
Voltage 14.8 lithium xs power cells
2000 gmc jimmy no wall box
amp wired to 1ohm did test burb and box rise 3.3ohm
Could always wire down to .25 seems with impedance rise you would see closer to 1 ohm.
Don't blame you on that. The other thing is you can try to build a different box that has less impedance rise, so the subs see more power.
Thank you
Different box is much needed in my opinion probably something that will be more efficient, something different than what you currently have, but it's really hard to say since you listed no specs except for the alts/subs/amp that you have. So really  everything is just a guessing game on our part since we don't know the vehicle, wiring, batteries, specs of your box in terms of the size, port, orientation, etc.
2000 gmc jimmy, amp wired to 1ohm, three banks 35ah xs power lithium cells, 3.5cuft per sub after displacement, subs up four 15”, two 10” aero ports firing toward tailgate
  • 3 months later...
you should be charging the bank to 15.3 - 15.8 volts  ...
  • Who's Online   0 Members, 0 Anonymous, 5823 Guests (See full list)
