Avalanche Build "nighttime" More Videos 6-15
I just spent another 3 hours working on the midgate and feel like I made little to no progress. I got all the mounting figured out and then spent forever trimming extra fiberglass off the back of the midgate with a dremel so that the box will mount flush. It just sucks to work that long and have so little to show for it.
Rebuild coming soon
It's alright, man. (Or Mang or whatever the people from Cali say. :lol: )
It will be worth it in the end.
off to a good start... i would put fiberglassin somewhere in the topic title so gp2k2 or lsn2meboom916 or coogle or some of our other glassin pros can stop by and give some tips
I am here (for what that's worth)
I have little to say thus far...because everything looks kosher up to this point...I'd like to see some pics of the "dremmel work" and "trimming" just so see how "close" it's trimmed.
It really looks good so far tho bro, keep it up.
It is a tight fit. It is a mold of the factory midgate which will attach to the factory mounts and hinges, then bolt the box to that.
I like this idea/method. Nice job.
I'm lookin forward to seein how this ends up.
I feel ya bro.
I been hand sanding and the pics are no biggy even tho it's like hrs+hrs+hrs of labor.
That's the name of the game tho...keep it up, so far everything looks good to go. Keep snappin pics....especially of the fitment and the use of the stock mounts sounds interesting.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
Did some more work today.
Here is the dremel work I had to do to make sure the box attached flush.
Posted Image
My Redneck router jig.....
Posted Image
Posted Image
Test Fit....
Posted Image
The blocks are where the factory mounts attach.
Posted Image
And then 3 more layers of Resin and mat.
Posted Image
Still got a lot of work left to do.........................
Rebuild coming soon
Quick question.... Would I be ok to use body filler versus kitty hair? I know kitty hair is stronger but are there any other pros or cons? With 10 plus layers of resin and mat would I be ok with body filler?
Rebuild coming soon
depends on WHERE it's going.
If it is an area that will see lots of pressure or vibration I'd say use kitty hair filler and then filler in over that to finish in all the holes (kitty hair filler almost always crates lots of gaps/holes to fill).
If it's purely cosmetic, then just filler would be fine.
In eiather case you should mix in resin with your filler (about 20% resin, 80% filler) so that it will self level and save you a bunch of time on sanding.
Genius.... I would not have thought of that. Thanks for the heads up.
Rebuild coming soon
Yes sir that trick works well..
Lookin good bro.....looks like a lot of "fun :rolleyes: " doing test fits, don't you just love those :) I'm sure those woofers are gonna slump.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Any time my man.
I should also add...
I have "been instructed" by some "pros" directly (said to me) and indirectly (I read it in someone else's build log as they were told to do it)
"You will need to mix in both the filler hardener AND the resin hardener"........
HOWEVER!
Dats a load of crap from my exp.
I have done it BOTH ways and the only "advantage" if you can call it that, is that you can mix everything "cooler" or "lighter" on the hardener/s...but you will run out of BOTH sooner....
I had originally heard this trick WITHOUT the mention of using resin hardener AND filler hardener so I just started using the 80/20 rule and using ONLY the filler hardener...
FOR ME PERSONALLY....that seems to be the best mix and provide a quick set time, low to med tackiness and it alllows the bubbles to surface and "pop" so you have less pinholes to putty later.
Just my way of doing it here in the cali summer heat and "almost" cold winters...you do what works best for you.
And git crackin! :P
