HawkVenom Posted February 5, 2023 Report Posted February 5, 2023 I understand before setting amp gains, you need to find your HU max volume before clipping. However, since i play my music from my iphone(13) through the Youtube Music app via Bluetooth, shouldn't i need to find the max volume on my iphone first, since its actually the source? I usually just turn the volume all the way up on my phone then find my max HU volume before clipping but if my phone clips at max then wouldn't mess the whole process up? Wouldn't that be the same as setting amp gains without finding your HU max level? I watched Steve's old video on finding an ipads max level before clipping and one thing he did was use a rca adapter directly from his ipad to his amp thus bypassing the HU all together. Is this the same process i need to do with my phone to find, if any, distortion at max volume? Also, does the Sound Check option in my iphone setting need to be on or off?? Seems i read something about it needing to be off, mine has been on this whole time. Anyway, sorry for the long thread!
Ron36 Posted February 5, 2023 Report Posted February 5, 2023 I like your question, I only listen via Bluetooth and some songs are louder then others and some are crystal clear, some sound like garbage and make me think my mids are blown. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
HawkVenom Posted February 14, 2023 Author Report Posted February 14, 2023 to give a bit of an update. I ordered some lightning to rca adapters for my phone. I measured the voltage of my phone (at max volume) with both 1khz and 40hz test tones and got less than a volt. With the DD1, i get a signal but no indication of either test tone being played, is the voltage why?
Joe X Posted February 15, 2023 Report Posted February 15, 2023 That signal is too small, the DD-1 needs about 1.2 V rms to work.
HawkVenom Posted February 15, 2023 Author Report Posted February 15, 2023 15 minutes ago, Joe X said: That signal is too small, the DD-1 needs about 1.2 V rms to work. Thank You, are you able to see my pictures i uploaded? I cant see them from pov. I wonder if i did something wrong.
Joe X Posted February 15, 2023 Report Posted February 15, 2023 Use .jpg format and the images will show.
HawkVenom Posted February 15, 2023 Author Report Posted February 15, 2023 14 hours ago, Joe X said: Use .jpg format and the images will show. ok, thanks for your help, I went back and watched steve's video again and he did in fact mention about the voltage issue with just hooking up the DD1 directly to an ipad or iphone. I had missed that somehow when i previously watched.
nauc Posted February 21, 2023 Report Posted February 21, 2023 just measure at the amp outputs. turn each piece of gear up until it clips. if the phone or deck clips, it will show at the amp outputs if you turn the amp gain up enough to register Alpine 9887, Oz 180CS, RF R500X1D, 12" RE SE
HawkVenom Posted February 23, 2023 Author Report Posted February 23, 2023 On 2/21/2023 at 2:13 AM, nauc said: just measure at the amp outputs. turn each piece of gear up until it clips. if the phone or deck clips, it will show at the amp outputs if you turn the amp gain up enough to register Thank You!
