Z1 Problem?
ok so i got everything finally wired up in the F-150 but i got a problem now and i think its my Z1.
i get power to the amp, but no output. RCAs are im the right spots. and the speakers wired up right, but i still have no output. after adjusting the gain back and forth, my clip light doesnt come on or anything, which shows its my amp or my RCA's, i dont think its the RCAs cause i mean i pulled them and swapped them right in. but its still a possibility. i am thinking, its blown channels on my amp or my RCA inputs on my amp are bad. eithier way its gonna cost me money :(.
cant i put my hot speaker lead from my woofer on the battery input and my negative input on my ground terminal?? wouldnt i get some output from that??
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Multimeter?
aint got one.
but i know i should probably check the outputs from the speaker terminals. ill have another amp to check the RCAs with tommorow.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
check your ground, my friend had a pioneer amp that wasn't working, I went through EVERYTHING and gave up, he came back a few days later we changed fuses and then I moved the ground it it worked perfectly.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
ill get a picture where its grounded tomorrow.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
a DMM cost like $15-20 from sears.... check your fuses remote trigger wire and headunit wiring...
edit: get the DMM its worth every penny.
Edited by wL<3bass
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
everything with wiring except maybe the ground is fine.
but i have 2 1/0 gauge grounds so, idk.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
No need for a pic, I'm just saying, try a different location. You have the same symptoms as he had
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Seriously?
o____O
You'll got a loud POCK, a spark, then the happy smell of really really burnt voice coils.
Can you tell if the amp is powering up? Does it go into protect or do nothing at all?
You really really need a DMM to check voltage at the terminals. Also check you wired the power the right way around, although you probably would have just got a big spark + smoke if you got that the wrong way round... with my big amps the 2 power terminals are opposite ie from left to right across the amp it goes + - - +
EDIT: If you're using an EQ or processor or anything like that between the headunit and amp the amp will instantly shut down if there's an issue with the device inline. My amps won't power up if the RCAs are connected to my processor when the processor isn't powered up.
Edited by Boon
10.x volts fo' life!
  • Who's Online   1 Member, 0 Anonymous, 445 Guests (See full list)
