Very Low Numbers
an electrical system is only as strong as its weakest point
and sometimes they screw up those tests, if you can beat pretty well without dropping significant voltage, then your fine.
but i would upgrade that last 4 gauge cable to full out 1/0
very much understood. It confused me when he said to run 4 gauge cable for my charge lead, and when I asked him why, he talked about the alternator needed a certain amount of resistance to properly charge, and he said that H.O. told him this, so I went with it, now I am 2nd guessing the whole thing.
Loud as f*ck, and sounds good doing it.
Team built from here on out!!!!
BIG things to come.........
Missing link is the shite!!!
nope, system was not on, and I spoke to an installer who has done some big spl installs and was told that he had a very in depth discussion with someone at H.O. and they let him know that 4 gauge should be the largest charge cable to run considering the installation, even though it is a 225 amp alt. I plan on looking further into this because most people on here are running 1/0 gauge and how can you argue with results? right? anyways, if anyone has any questions or possibilities, please respond. Thanks,
Joseph
4 gauge wire is all you need to run power. 1/0 wire is used for homes. The terminal on the battery and alternator aren't even suppose to hold 1/0 wire. Why people keep spending all this extra money on 1/0 wire for car systems is beyond me. :blink: The extra thick cable you see running from your fuse box in your house that runs your AC, dishwasher, microwave, furnace, refrigerator, stove, etc is 1/0 wire. Did you get that? 1/0 wire runs every electrical device in your home. Why anyone would need that wire to run a car system is beyond me.
the bigger the wire, the better the flow of voltage.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
at 110+ volts vs 14 volts big difference
DC.jpgDC POWER
voltage does not flow current flows. the higher the voltage the easier the current (electrons) will flow
DC.jpgDC POWER
lots of amperage. I was originally going to run 1/0. Lots of amps needs lots of cable surface. house is ac. from what I understand it is a huge difference.
voltage or amperage? or both? Just trying to learn man. not trying to be a smart ars.
dont houses use way less amperage?
however it goes. i'm sure you all get the picture. anyways the bigger the wire the better.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
WOW Seriously?
I'll tell ya what bud, why don't you use some 14/3 romex to power you system and let us know how that works out for ya ;)
  • Who's Online   0 Members, 0 Anonymous, 4045 Guests (See full list)
