Hannahs car is Out of Commission right now do to her clutch being GONE.
its weird, happened over night (symptoms started last night, car not drivable by this afternoon)
the car starts and runs strong in N but when the clutch is pressed it does not engage and forcing it into 1st promptly kills it. the clutch uses a wire not fluid and the lever just above the clutch/side of heads pivots just like it should.
we think the clutch is just out but the tow truck driver claims up and down the clutch just needs to be tweaked and is not done for.
anybody with experience know whats going on?????
-Drew
uhoh_45 said:
what kind of car follow along the clutch cable make sure its not broke check where its connected to tranny see if it moves when you push clutch in also see if it has a adjustable nut on top that you can adjust. good luck
yup the line is in good shape and ive already tightened that adjuster bolt :(
-Drew
I would also say its not done for i had to adjust my buddies integra the same thing happend to him i loosend it and its doin fine now.
Youtube.com/J Hutch22
hmm are you talking about the adjuster thing by the clutch peddle? new cars use a wire to engage the clutch now? if they didnt i would say check the fluid or make sure your slave/master cylinders are working properly. it is highly unlikely that the clutch is just gone, clutch in my car went and was still drivable just had to force it a lil speed shift.
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
Has to be another linkage for the clutch i dont think its shot, you would probably smell it and it would have started grabbing and bein jumpy far beforehand it has to be an adjustment somewhere.
I wanted a good entry level system...Kenwood KVT-512 7 inch touch screen.Went with alpine... 2 Type R 15's @ 4ohms powered by 2 MRP-M1000 amps, dual 2 farad caps, Type R 6x9's and 5x1/4's, Optima battery and HO Alt soon to come. All in the back off my 03 Pontilac bonneville. Simple but effective.
The easiest way to tell if the clutch is fried is that when it is engaged it will slip. If you have no slip, than its just out of adjustment.
2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
So the pedal just falls on the floor right? and it's a mechanical clutch? Same thing happened to me in a neon. The cable just came off a hook on the transmission.
816-591-6592
www.kcrimshop.com
