Im getting a FiBTL 12'' model loaded and before i order it im a lil confused about how my wiring options are going to be....I am going to be running two memphis 1100 class d amps. they are 1100RMS@1ohm, 600RMS@2ohms, and [email protected] want to be able to get a 1ohm load out of both amps so i can be pushing at least 2200RMS to the sub....but im not sure which Dual1, or Dual 2 i should order....any help will be greatly helpful............i am also getting a D2700 batt and a 200amp alt to complete the system...thanks
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
You want th d1 if your gonna run one amp to each coil better know how to line match amps or your gonna smoke that sub
What he said ;)
I would suggest looking into getting a Maxx-link. It will make your life easier when running multiple amps
What he said ;)
so i just run the two amp together. i have not yet gotten a good look at an FiBTL ...does it have just one set of +- or +- +-
and i will be running a 1ohm load to each coil then?? (ive been into the audio for about 2 yr and still learning)
1 3500d AQ amp
i talked to the guy at my audio shop in town that i deal with. he said not to recomend hooking up two amps to the sub for dail driving. he said that it will burn the sub or something. but these subs are supose to be able to take 3-4krms so what does it matter if i run two amps to the sub at 2200RMS???? am i right or wrong? put it this way, will it mess the sub up running two amps to it
1 3500d AQ amp
no it wont mess your sub up with running two identical amps to it but like kingsuv said ......... get a maxxlink.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 2596 Guests (See full list)
