8" Or Other Size Midbass
i am looking for some 8" or 6-1/2" midbass to go in my driver and passenger doors. i have 2 15" mtx 9500 on a TE4001d MTX amp and those do the lows but i was looking for something to do the mid and high bass frequencies. please leave suggestions and also an amp for them if needed. thanks
look at the kicker ss series they do 30-500hz and are available in 6 3/4" and 8" or you could go with sundown e8 if your playing 200hz and down on them.
Edited by wL<3bass
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Kicker SSMB series.
8 inch and 6.5 inch models designed and dedicated for midbass use.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
If you want something cheap to play with, parts express has some really cheap 8's. I put a $20 8'' in a audiobahn bass tube with 70 watts and it destroys my first system [visonik 10's and amp from pep boys lol]. I was impressed for the price and power. [although it doesn't like 23hz tones lol]
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
You could try these aswell they also make these in an 8" driver.
http://www.partsexpress.com/pe/showdetl.cf...tnumber=264-874
My YouTube Videos
http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=14424
Specs:
* Sensitivity: 88 dB
* RMS Power Range : 8-125 Watts
* Peak Power Handling: 250 Watts
* Impedance: 4 Ohm
* Low Frequency response: 30 Hz
* High Frequency Response: 500 Hz
* Diameter: 6.75 Inch
* Tri-Tech cone (sandwiched foam, polypropylene, and woven carbon fiber)
* Santoprene rubber surround
* low profile stamped steel basket
* spring-loaded nickel-plated terminals accept heavy-gauge speaker wire
* free-air capability
* flush-mount depth: 2-1/16"
* Priced per pair
I think they are you best bet and are only $70.
edit:
http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=14423
Specs:
* Sensitivity: 89 dB
* RMS Power Range : 40-175 Watts
* Peak Power Handling: 350 Watts
* Impedance: 4 Ohm
* Diameter: 8 Inch
* flush-mount depth: 2-5/16"
* Priced per pair
$99.00
Edited by wL<3bass
My YouTube Videos
go big or go home
OW-10PRO OW-12PRO OW-15PRO OW-18PRO
800w Power 800w Power 1000w Power 1200w Power
400w RMS 400w RMS 500w RMS 600w RMS
85 oz Magnet 85 oz Magnet 90 oz Magnet 130 oz Magnet
3" TSB Voice Coil 3" TSB Voice Coil 4" TSB Voice Coil 4" TSB Voice Coil
SPL 99 dB SPL 99 dB SPL 99 dB SPL 98 dB
Xmax: 4.7mm Xmax: 4.7mm Xmax: 4.0mm Xmax: 6.0mm
COMMON FEATURES OW-10/12PRO
COMMON FEATURES OW-15/18PRO
3" TSV
Ultra high temperature and low mass.
high power and high efficiency
Machine, Die cast aluminum basket
low carbon steel to pas smagetism easily
Under-cut pole-piece.
Extra thick top-plate and back-plate
Very large and high ceramic 8 (Y35+)
strength
Strontium magnet.
Ultra-light weight paper cone
Pure mid-range sound
Plasticized cloth surround
4" ASV
Ultra aluminum basket
Die cast auminum basket
Low carbon steel to pass magnetism
easily
Optimum mass cone to allow accurate,
controlled, and extended low frequency
Long lasting and low mass
----reference's----
meade916
componets are old do some 10'' evs for the mid bass and 6-1/2 o2s for the mid radge
HEY THIEVES AND HATERS ARE YOU BIGGEST FANS TREET THEM LIKE YOU DO THE REST!!
16 12" re re's
8 O2 AUDIO 6 1/2''
4 10'' EV'S
2 RD AUDIO 1750.1
6 MAXRATE BATTS
12 WHELEN STROBES
22'' TIS 07
  • Who's Online   2 Members, 0 Anonymous, 609 Guests (See full list)
