Team Bassick - Kimo Posted June 10, 2008 Report Posted June 10, 2008 OK lets get going on this. lets set some criterias and lets set a date. I'm sure we can get a hold of an amp from each side just to put this to an end any predictions? http://www.stevemeadedesigns.com/board/ind...c=23167&hl= KIMO @teambassick http://www.teambassick.com
Torres Posted June 10, 2008 Report Posted June 10, 2008 send me a 2k6d and i'll figure it all out EDIT: i'm sure it'll be close. like the RF and sundown. either way you're gonna get a good amp
IH8PunkRok Posted June 10, 2008 Report Posted June 10, 2008 as soon as possible for the date. if u can set a constant voltage for both amps. measure current draw at 4 ohm, 2 ohm and 1 ohm also measure wattage at each ohm load. the more efficient more powerful amp wins simple as that -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Derrick824 Posted June 10, 2008 Report Posted June 10, 2008 Sundown Saz-300d SPECIFICATIONS: 3000 x 1 watts @ 1 ohm 1600 x 1 watts @ 2 ohms 800 x 1 watts @ 4 ohms 0.2v - 6v adjustable input sensitivity 10 Hz - 350 Hz Frequency Response >90 dB S/N Ratio 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current) Linkable to another SAZ-3000D for up to 6000 watts @ 2 ohms 35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover 10 Hz - 60 Hz adjustable 24dB Subsonic Filter 0 - 180 degree adjustable phase shift 0 - 18 dB adjustable bass boost with 45 Hz center frequency Wired Remote Control unit included 300-amp external fuse required 23.4" L x 9.9" W x 2" H Stetsom 2k6d SPECIFICATIONS: RMS Power @ 13.8V <0,9% THD Mono 2 Ohms: 3000 Watts Mono 4 Ohms: 2200 Watts Mono 8 Ohms: 1200 Watts RMS Power @ 12.6V <0,9% THD Mono 2 Ohms: 2600 Watts Mono 4 Ohms: 2150 Watts Mono 8 Ohms: 1050 Watts Minimal Input Impedance: 0,2V Total Harmonic Distortion: < 0,9 % THD Signal to Noise: > 90 dB Crossover Frequency LOW PASS: 50 to 15 KHz Frequency Response: (FULL RANGE) 20 Hz to 15 KHz (-3dB) Input Tension: 9 to 16V Power Consumption: 3,3 to 240 A Dimensions : 70 x 280 x 330 mm
IH8PunkRok Posted June 10, 2008 Report Posted June 10, 2008 also u can try an ohm load test. u know whoever goes lowest (at a set wattage) without frying wins. just for fun -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Derrick824 Posted June 10, 2008 Report Posted June 10, 2008 If the amplifiers owner's are up to it, I wouldn't mind seeing these tests go past rated impedances and include 0.5ohm and 0.35ohm tests.
reinke Posted June 10, 2008 Report Posted June 10, 2008 If the amplifiers owner's are up to it, I wouldn't mind seeing these tests go past rated impedances and include 0.5ohm and 0.35ohm tests.the sundowz can go to 1/2 with no problem ----reference's---- meade916
Derrick824 Posted June 10, 2008 Report Posted June 10, 2008 the sundowz can go to 1/2 with no problem Gee, I would've never thunk it?!? I have of course already played/tested both the Sundown 1500 and 3000 at low impedances and know what they'll do but thanks for letting me know anyways. Now lets see it in this official test.
reinke Posted June 10, 2008 Report Posted June 10, 2008 Gee, I would've never thunk it?!? I have of course already played/tested both the Sundown 1500 and 3000 at low impedances and know what they'll do but thanks for letting me know anyways. Now lets see it in this official test. sorry i just wanted to chime in here. i was bored. lol ----reference's---- meade916
Team Bassick - Kimo Posted June 10, 2008 Author Report Posted June 10, 2008 Gee, I would've never thunk it?!? I have of course already played/tested both the Sundown 1500 and 3000 at low impedances and know what they'll do but thanks for letting me know anyways. Now lets see it in this official test. sounds great....... Its hopefully the first of many but lets not go to far on that. The last thread got so carryed away and that it was finally in an agreement to put the two amps in one vehicle given the same equipment, box rise and voltage and see what they do. Each amps gonna have pros and cons. I hope to be there to document this test. I really would like to hear some ideas or scenarios to simiulate. Temperature is gonna be a factor as well as elelvations all of which we will do our bet to record. Scenario I had was: two boxes- An SPL Box tuned between 50-70 hz and then your everyday tuned between 30-45hz. maybe even a sealed box. what else? KIMO @teambassick http://www.teambassick.com
