audiofanaticz Posted December 13, 2006 Report Posted December 13, 2006 if its hooked up correctly you shouldnt be blowing any fuses yea, I wouldnt really be running it at 2 ohms mono (higher grade stuff is ok, but lower end things wont take it too well. I can run my amp below .5 ohm as a daily driver if I wanted, but I got a decent amp). You should be able to run both l5s off them at a 4 ohm load mono if they are dual 4 ohm coils on the sub.. Running the amp at a lower ohm is going to make it demand more amps, and the smaller fuses will blow from the amp trying to take more then the fuses will allow.
Ernesto Posted December 14, 2006 Report Posted December 14, 2006 no he does not have the opti, the other post he posted on about the lanzar vibe 286, and he said he has that ampo (the 286). read the other post. :^ i bought my vibe amp for a hundred bucks. id say i got an allrite deal. i can sell it for more if i have problums with it. his problom is the cheap amp Didn't see that ;D
