2 Ohm Stereo Or 8 Ohm Mono?
jonathancullen89
alright i dont know what to do, i can either wire the sub(dual 4) down to 2 ohms and wire it to one of the channels on the amp. otherwise could i wire it to series and bridge the amp?
here are the specs of the amp
4 Ohm RMS Power: 2 x 150 Watts @ 13.8 Volts
2 Ohm RMS Power: 2 x 300 Watts @ 13.8 Volts
4 Ohm Bridged RMS Power: 1 x 600 Watts @ 13.8 Volts
would running it bridged with an 8 ohm sub give me the 300wrms i need for the level 2? wouldnt it be more efficient. i need somebody's advice, thanks.
john
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
yes 8 ohm bridged would be 300 whats.
8 ohm bridged is the sum of the wattage of your 4 ohm stereo numbers.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
same power either way you go.
i would run it 8ohm mono
as would I
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
alrighty, i get the cadence tomarrow (supposed to be here anyway) but for now im going to wire everything so it will be a quick install. thanks for the help guys, box turned out great btw. hopefully it sounds good.
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
shit ton-o-wire
Team SMD
alright got the amp and got everything installed today! big difference going from 25wrms to 300rms lol. now i have another question. when installing the amp i had to turn the gain up quite a bit in order to make the sub loud, there is no audible distorsion and i turned the gain down a little after i could start to hear it. but right now my bass boost is on about +10, gain is almost 3/4 of the way up, and bass knob is at 50%. ive never had to turn an amp up this much, is it because i am running it at 8 ohms? the subwoofer is deffenetly louder and sounds alot better after i added more power but i just dont understand why i had to turn the amp up so much. any ideas? thanks
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
shit ton-o-wire
Team SMD
  • Who's Online   0 Members, 0 Anonymous, 2154 Guests (See full list)
