I have a few questions for Jacob about the 3000's. I was wondering how to get ahold of him? I am really interested in running a pair of them at 1ohm each and I was wondering if my upgrades will be enough?
My Plan:
Mechman 250amp Alt
4 Kinetik HC2400's or Powermaster D3100's (Still need to talk to Scottie)
2runs of Knu Konceptz 1/0 Power to the batts
2runs of Knu Konceptz 1/0 Ground to the batts
1/0 from batt to batt, then 1/0 from batts to each amp
Should I be tough enough to pound them daily at 1ohm or do I need more? Should I run them daisy chained and gain matched or strap them at 2ohm? Subs are 4 15" dual 1ohms.
HU: JVC KD-AVX1Speakers: Stock BlazerSub: 2 Mass Destruction Car Audio Sidewinder 12"Amp: Orion HCCA-D1200 @ 1ohm (600 RMS)Box: 3.0 cubes tuned to 35
My Plan:
Mechman 250amp Alt
Give Jacob time... he will answer.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
The alternator is a bit small, IMO, to run 6000 watts continuously.
It really depends on how you run your equipment - if you mainly listen to actual music that doesn't tend to approach 100% of the amplifier output potential then you will be fine with the 250-amp alternator. If you like to have the amps full blast at all times a 250-amp alternator won't cut it with 600 amps of current draw.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
7 MIN RESPONSE SUNDOWNZ FTMFW
-Drew
Edited by Noobtastic14
uhoh_45 said:
Well I'm definately not going to be playing Bass Mekanik full tilt for an entire cd or anything like that. I will more than likely turn the amps down for daily listening and then when I do bass race turn them up so, it won't be hard pounding all day. I will more than likely listen to music for 30 minutes tops at a time and not full tilt. If it comes down to it I may actually run one 3000 daily and 2 for bass race it just depends. I figured with 250 amps and a bank of 4 2400's I should be alright. Am I wrong? So I guess to answer you question in short I'm not going to drive them to their fullest hours on end.
Sounds like you will be just fine then :)
- Jacob Fuller
Alright thanks. I wanted to make sure because I don't see spending $1800 in amps for them to fry. I am pretty experienced and I know your products are goot so I figured if I watched it and kept the gains down for daily I should be alright I just wanted to check. You guys are right Jacob is a good guy. Thanks
Alright thanks. I wanted to make sure because I don't see spending $1800 in amps for them to fry. I am pretty experienced and I know your products are goot so I figured if I watched it and kept the gains down for daily I should be alright I just wanted to check. You guys are right Jacob is a GREAT guy. Thanks
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
