Should I be tough enough to pound them daily at 1ohm or do I need more? Should I run them daisy chained and gain matched or strap them at 2ohm? Subs are 4 15" dual 1ohms.
I think you'll be alright as long as you're not playing full tilt all the time. A good precaution would be to install a nice digital volt meter up front so you can keep an eye on it. As for the amps I would run them strapped just for the convenience of only needing one remote knob.
The remote knob is a good point and since I'm going to be needing it so i can set my gains then turn it down daily and then turn it up for comps it would be much more convenient to turn it down and up with a knob than screwdriver and dmm. What will a strapped pair do at 2ohm? 6200-6400?
HU: JVC KD-AVX1Speakers: Stock BlazerSub: 2 Mass Destruction Car Audio Sidewinder 12"Amp: Orion HCCA-D1200 @ 1ohm (600 RMS)Box: 3.0 cubes tuned to 35
whats the minimum voltage that the sundown amps will run safely on .5ohms or 1 ohm strapped?
I don't suggest letting your voltage sag under 12 for extended periods of time - if it does that means your charging system is inadequate.
It's pretty uncommon to see any issues above 11 even for long periods, though -- on burps into the 10s really won't hurt them. Many people running them in "street" with one battery drop them down like that frequently for burps without issues.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Also, when i strap the pair do I turn the phase 180 on the Slave amplifier? I know you do on my orion's but I didn't know how that BR ouput worked and if it did or not.
Yes you'd switch the phase to 180 on the slave amp if I remember correctly.
The *** forums has a tutorial for strapping the amps. ;)
Can Jacob chime in on that? I looked on *** and didn't see where it specified.
http://www.soundsolutionsaudio.com/forum/i...?showtopic=7406
EDIT: Just looked there and didn't see anything mentioned about the phase switch setting.
Edited by emat19876
The BR out from the master amp does that automatically. No need to mess with anything on the slave amplifier. Simply run a single rca from BR out of the master amplifier to BR in of the slave amplifier, adjust settings properly on the master amplifier, and you're done.
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
