Does A 300+ Amp Alt Exist For A 02 Tahoe?
Can someone point me in the direction of H.O alts? I dont like ebay stores, but if that is the only place, which store is recommended? Thanks
iraggi, powermaster, ohio generator and excessive amperage. try those first
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
yes there are LOTS of 300a alts out there and they all say the same thing. Your "at idle" will suck but after 800-1000rpm its awesome.
I recommend Iraggi myself but if anyone else wants to give this guy some numbers USE PM's or the FOR SALE section.
Follow my Tweet (Twitter)
thank you, can someone tell me if this is the correct direct replacement alt for my tahoe... It comes factory with the 130amp, and the stock replacement part number is 8237, and this Iraggi alt say it is compatable, but want to ask here first. http://cgi.ebay.com/ebaymotors/300-amp-Ira...itemZ7955208394
Edited by newls1
I love my staffie :good:
So anti FACEBOOK it isn't even funny
You need the AD244 Alt for your tahoe from who ever. The iraggi listed is the same AD244. You need to look @ idle output if you park and play alot. Idle is where you need the most power output(I feel). Just depends on your style!
You really have 2 options:
high output above idle
better output @ idle
all companies spec are different so try to see where you fit in. If you demo alot you want higher @ idle if you drive more than demo then the higher while driving should be fine. Double check where your vehicle's idle sits then compare to the alts idle needs. Some alts do not even turn on till over 1000RPM's so look at all of these so you get the best for your needs.
Oh we fit AD244's :D
MLA
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
MLA
Well, I emailed Dom, and about 2 minutes later I had a response (damn that was fast) I think what im going with is a Dual ALT braket, and his 300amp alt, to run "WITH" my stock 130amp alt. Does this sound logical, and how would I wire it? Would I just keep the stock alt "left alone" and wire the 300amp alt to my amps and extra batts? Here is my understanding of electrical, "I leave it alone, and it leaves me alone!" Everytime I do electrical somehow or someway be it either home or car, I get shocked. Doesnt bother me, however one day it is going to bite me hard!......... Does anyone know how much the dual alt braket costs around?
If you have a second battery then it will be possible to run the 300 alt to that battery(i believe) and run just the audio off it
2 MAW15's
Cadence 1000D
Infinity Reference 6022's
Blankput Tweeters and Infinity 4x6's with tweeters
Powered by a US Acoustic USB4085
1 Rockford 1Farad Caps and a 200 amp ALT
Yes, I will have 1 or 2 batts in the rear, so what im talking about IS POSSIBLE? Would it be better this way, or NO? Cause my other thought is this: If I use both alts, that is a combined amperage of 430Amps, so maybe this is the better way to go. I just have no idea how to wire this bitch in.
  • Who's Online   1 Member, 0 Anonymous, 1328 Guests (See full list)
