Is My Duralast Gold Battery Hurting My Voltage?
Is my Duralast Gold battery hurting my voltage?
I have an Excessive Amperage 250A alternator, one Duralast Gold Size 65 battery under the hood wired in parallel with two Kinetik HC1800 batteries. I have the 3 batteries connected - to - to - and + to + to + (I have two runs of 1/0 going the length of the car), but only the Duralast under the hood is grounded to the chassis. My voltage driving around is usually 13.8V at the amplifier (with the stereo turned down all the way, but on).
I took my car to Advance today. I unhooked the two 1/0 runs at the Duralast that connect it to the Kinetiks. They tested the battery and came up with 12.59V and 958CCA. I kept it disconnected from the Kinetiks and I had the guy test one of the Kinetiks. The Kinetiks were still wired in parallel with eachother when he did the test, but not grounded to the chassis because only the Duralast is. The test gave 13.06V and 1095CCA. I wish I disconnected the Kinetiks from eachother and had him test them separately, but they were closing in like 2 minutes.
What can you guys tell me based on these tests?
Thanks a lot.
Edited by eazy
1999 Mercury Grand Marquis LS
Build Thread
Pioneer DEH-P5000UB
(4) Infinity Kappa 682.7CF's
Sundown Audio SAE-1000D
Sundown Audio SAX-100.4
Fi Q15 with BP power in 4 cubes @ 32Hz
(2) Kinetik HC1800's
Duralast Gold Group 65
Knukonceptz Kolossus 1/0 gauge
Elemental Designs eDead v1SE²
Anyone?
Build Thread
Pioneer DEH-P5000UB
try grounding the amps in the back if you can.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
The amplifiers are grounded on the battery negative of one of the Kinetiks. Did you mean ground the Kinetiks? I have 1/0 connecting all the negatives together.
Build Thread
Pioneer DEH-P5000UB
i got a run of 1/0 negative running back to my kinetik HC800 and i didn't ground the battery in the back but yet i have both of my amps grounded to the frame.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
The votlage is different because Kinetiks are AGM batteries. The resting voltage of an AGM battery is usually around 13.1V, wheras a flooded type battery (like your duralast) rests at around 12.6v. This doesn't cause a problem persay, but your resting voltage will never be as high as if you were to run all AGM batteries.
Okay sweet. Thanks a lot guys. Yeah my back batteries are not grounded to the frame. I have a battery negative run going from the rear batteries to the front battery. The front battery is grounded to the frame. The amps are grounded to the rear battery negative. So would I be better off to get rid of the Duralast and get like an HC800?
Build Thread
Pioneer DEH-P5000UB
  • Who's Online   0 Members, 0 Anonymous, 1451 Guests (See full list)
