Am I gonna be able to run 4 subs off of a mono amp?
What subs are you talking about? You'll more than likely be able to run all 4 off a mono amp. I do, and did in the Beretta (god I wish I still had that car)
140 to 180 amp alternator + Couple yellow tops + Big 3 upgrade = set to go.
Team Pinnacle / Team SouthEastSPL / Team SoundStream / Team GPI / GPI Sales Rep for Florida and Georgia
The 4 channel amp I was looking at was a lanzar. so if i get say, an 800 watt mono amp and run 4 subs off of it it'll send 800 watts to each sub? Sorry for all the questions. I'm fairly new at this.
06 Taurass SE
1 PPI Pro104
MTX TC 4001D Amp
1.5 CU. at 34 hz
After Christmas...
2 PPI Pro104's
Audiopipe 1500D
3.4 CU. at 35 hz
it still depends on the subs( what ohm the voice coils are, and if they are single or dual voice coils) and what ohm the amp can be safely played at. but yes, you can run 1,2,3,4,5,6,7,8,9,10,...... subs off a mono amp.
The subs I was planning on getting have single 4 ohm voice coils and the amp is an 1100 watt power acoustik class d2 mono block amp.
06 Taurass SE
1 PPI Pro104
MTX TC 4001D Amp
1.5 CU. at 34 hz
After Christmas...
2 PPI Pro104's
Audiopipe 1500D
3.4 CU. at 35 hz
wut u gotta remember is the rms power that is being put out is split up amongst the four subs equally.
so say u have four subs that are rated 500 rms u would need an amp that is 2000 rms.
with 4 single 4 ohm coils u can get a one ohm load. wut are the subs and rms rating on them?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
1 ohm load but not limited to other ohm loads. It being a power acoustik amp, it may not be stable at 1 ohm.
you can also run all 4 subs at 4 ohm, or 16 ohm :) lol
u r correct.
lol @ 16 ohms though. @ that ohm load u would prolly get like 300 watts out of an RF T4000.1bd lol
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
The subs are logic sound labs mdx's. It says they can handle 750 watts rms.
06 Taurass SE
1 PPI Pro104
MTX TC 4001D Amp
1.5 CU. at 34 hz
After Christmas...
2 PPI Pro104's
Audiopipe 1500D
3.4 CU. at 35 hz
