i've got this amp its ample 1500wrms (old but good =]) and latley this thing has been getting red hot nothing hooked wrong never goes into protect just gets hot if been playing all day or not idk help plez
Vehicle:1998 Jeep Wrangler 4.0 I6 with Cherry Bomb and Cold Air Intake,
Speakers:5 1/4 Pioneers in front and back
Deck: Jensen DVD In-Dash
Amp: Lanzar Opti-Drive 2000w
Subs: 2 Boss Chaos Edtion 1000w max (500wrms)
Rubber: Nitto Grappler 35 x 12.50
Fun Things: Cobra CB with PA speaker to piss people off =]
If the listening level is too loud, then your not deaf enough
Pardon me while I go get my magic crystal ball from the shop.... :rolleyes:
Edited by emat19876
we need brand and model, what ohm load you are running, and is it really "red hot", if so then your metal is melting. If its in direct sunlight all day, sure its gonna be hot as hell.
more info and/or pics would be nice so we can help
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
Waits for reply from said crystal ball
Gotta hear this!
Ya need pics dude could be a lot things 2 small wire ohm load could be to low for the mystery amp your talkin about
ill have to go look and check and pics and its ample brand are coming its at a 2 ohm load and no its not in direct sunlight its monted on the back of my box but no its not so hot that its melting the metal but its melting the carpet 0624081930.jpg
What. the. fuck.?
Clean that wiring up.
What's your gain set to?
What. the. fuck.?
this was before i had done any cleaning up i had just got it mounted its set at 1/4 way
how did you set the gain? with any kind of meter, or just turned it up till it played?
looks like 4ga power wire, but I can't tell, you may want to try 0 ga
Where is it grounded?
If its in a small area it just may not be hetting enough airflow, try a 12v fan you can plug into the cigarette lighter and see if it helps, and if it does add a more permanent fan with proper wiring and switchs.
pics of where it is installed will do the best for us
Edited by hotshot27
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
Check the sub with a DMM to make sure it's still a 2ohm load and not something lower.
i just set it until there was no distortion its 2ga wire and it grounded on the seat belt screw only place in a jeep its mounted up under my rear seat you think an amp that big would come with a fan or something but yea it up under my rear seat
