i have heard, that kicker is doing 800/900rms besides rated at 750rms...its true?
so far, the kenwood its the price/money winner.. im right?
now, between the alpine and kicker.. the alpine is the most powerfull, but a little expensive, which I must choose?
thanks ppl!
by the way, the only reason i would go with alpine is I like the way they look better. It you get lucky, some 750.1's have been seen putting out over 1000 watts with the right electrical. But i would safely say 800rms atleast from the kicker.
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
I would say that the Alpine is going to give you the best sound quality out of the choices. But how much sound quality can you really get out of a class D amp? :) I had 2 Alpine MRD-M605's that put out 600 watts each at 2 ohm on a RE SX 12 and it did a 140.5 out of the trunk of the Escort that I had. They put out their rated power and they sound pretty good doing it too. My next choice would be the Kicker, but for the price difference you would be better off with the Alpine.
ok, thanks to all for the help. now only necessary to choose one of the two.
the sub that one of them will be run
diameter: 30 cm / 12"
power handling: 1000 WRMS
impedance: 2x 3,6 ohm
voice coil: 75 mm / 3"
excursion: X max. 25 mm / 1.0"
resonance frequency: FS 28,9 Hz
SPL: 89 dB
additional: double spider
Edited by CoolXoc
Kenwood is out.
Alpine and Kicker are good,but if it was me I'm a Kicker guy.
So Kicker is my opinion.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
I would go with the kicker too, those 750's pack a lot of power.
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
Kenwood is out.
X3 id get the kicker
ok, but why kicker? i need to know! thanks
