Two 1/0 inputs to feed the amp its power
Passenger side kick panel , tweeters are flush with the mid and share airspace.. sealing it up was a pain
The panels were molded to fit in the factory positions like a glove
After 3 days of working on them they came out pretty nice
I had the speakers in a cardboard box for a few months before finding the perfect spot for each one, then i fiberglassed the panels
Drivers side kick is a little bit bigger because i did not want to cut out the dead pedal, it was not removable
I had to cut the trim panel so i could get the angle and airspace i wanted with this panel
Robert Zeff designed Arc Audio KS300.4 , great improvement over my memphis both in imaging and tonal accuracy
Ultralink RCA's just to ensure that i dont ever have any rf noise that i shouldnt get
Close of up of the RCAs . they are unidirectional which i thought was pretty cool
Ran the RCAs to the sub aswell.. no reason other then just to match with the rest
Amp is secured to box and false floor, false floor and box are both secure to the cars chassis.. its not going anywhere
Everything is starting to come together .. still need to work on a few more pieces in the trunk and i can say its done
probably my favorite picture, the amp has 0.5" of breathing room on each side to keep things cool
Big three done in 1/0 gauge and routed and secured safely
main distro block, if you notice there are two runs of 8 gauge there, one for my headunits positive and one for negative, i know its pointless and overkill but i had the extra wire so why not
This setup did a 142.8 at a USACI event, it may not be the loudest like meade's stuff and the glass work may not be up there with timmays stuff but i really put alot of time into the car to get it loud and to get it to image properly and to get it as tonally accurate as i could using a test tone cd and a basic spl meter. Just my humble daily driver, enjoy the pics!
Too Much Stuff to list .
looks like you did an awesome job there bro congrats!! and dont' think you have to compare yourself to meade .. he is just a car audio BEASTT :) but this looks like an awesome install
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
hell i like it. very clean
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
You got a clean setup bro. You design your t-line?
"IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Powermaster S3400 & D3100
Iraggi 300a alt
SecondSkin - totally dead
Knu wire
