just like the tittle..could a stock alt handle more than 1 battery?...
Easily
I had my stock alt and 1 2400 and 2 Deka G31s and 500.1(5000watt) runnin at .7 and it was fine
Most the time your alt will just shut off and youll run off batt til your draw drops to something the alt can handle on its on, which still isnt a bad thing
I kept my batts charged which aided in my voltage....a 10amp charge bout 3 times a week overnight will do the trick
I dont know what amp my alt is stock...maybe 105ish
2004 Explorer4 12" Type R500.1(.5 ohm)6cu@35hz153@ 44hz
I got 2 batteries on my stock 105amp alternator, had 4 at one time.Not sure if it'd handle much more than that though.
Team Pinnacle / Team SouthEastSPL / Team SoundStream / Team GPI / GPI Sales Rep for Florida and Georgia
how can you find out how many amps your alt pushes or has.? :unknw:
i have 3 batts on mine... 1 yellow top and 2 kinetik 600s
Edited by Chode69
NoFearX18 said:
trainman0978 said:
I've had 20 batteries on one stock 140 amp alt.
It charged them all, just took awhile to fully charge them. ;)
to play it safe ........ if you're going to not upgrade to a HO alt, then when you do go adding multiple batteries, just remember to know blast it for long periods of time and when you're riding .... keep the sounds a lil low so they can charge back up.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Well first off what type vehicle?
Second it should be able to keep up to 3 batts up if you bench charge them first.
Added voltage to 15v will keep them up with a stock alt.
Simple easy fix mane!!! What type of car is needed for better answers for your topic. Thanks,
MLA
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
  • Who's Online   0 Members, 0 Anonymous, 1335 Guests (See full list)
