T10001bd Rattling
I am hoping someone has a solution for this. My T10001bd makes an aweful rattling noise from the top cover. Not the removable one but the one with the fan in it. Of course it only does it when the bass hits, has anyone else had this issue? Whats the best way to solve it. I was thinking about putting some dynamat underneath the cover, but I dont know how that will effect the cooling on the amp. :search:
n2caraudio.com
are the screws tight?
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
is it comming from the cover itself, or the plastic that houses the fan, or around the fuse?
Your best bet would be trying to take out the 5 small allen screws (2 on top, 3 on the front by the switches) and remove the pin by the rca input/output, and try to put the cover back on again. There is a small grove that the cover locks into place towards the top of the amp and maybe it fell out.
I will try that. its driving me crazy. I can touch the cover slightly and it stops rattling. I just havent had time to mess with it.
n2caraudio.com
I had a minnor problem with my T500.2.
It was the 2 aluminum tabs on the top corners (if your stairing down on the amp) weren't bent perfect so I had to adjust them alittle.
Around the cover of the fan you can try a thin weather stripping tape.
Edited by ISO
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
  • Who's Online   1 Member, 0 Anonymous, 595 Guests (See full list)
