A Couple Amp Questions
Big Papa
1.) Is SPL a good brand?
2.) I'm planning on getting 2 15's and a1550 watt mono block amp. The amp should put out 750 watts rms so will both the subs be seeing that power or would it be divided between the two?
06 Taurass SE
1 PPI Pro104
MTX TC 4001D Amp
1.5 CU. at 34 hz
After Christmas...
2 PPI Pro104's
Audiopipe 1500D
3.4 CU. at 35 hz
Which question were you answering?
06 Taurass SE
1 PPI Pro104
MTX TC 4001D Amp
1.5 CU. at 34 hz
After Christmas...
2 PPI Pro104's
Audiopipe 1500D
3.4 CU. at 35 hz
1.) Is SPL a good brand? NO
2.) I'm planning on getting 2 15's and a1550 watt mono block amp. The amp should put out 750 watts rms so will both the subs be seeing that power or would it be divided between the two? Divided between the two
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Thanks bro. What about crunch?
06 Taurass SE
1 PPI Pro104
MTX TC 4001D Amp
1.5 CU. at 34 hz
After Christmas...
2 PPI Pro104's
Audiopipe 1500D
3.4 CU. at 35 hz
It sounds like people are liking the Crunch GP series.
Use the search on this Forum and type Crunch or Crunch GP and you can probbly find 6 or 7 threads that contain info about them.
Then you can up with your own conclusion.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
get a sundoiwn SAZ-1500?
that'd get like 750 to each
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
both
  • Who's Online   0 Members, 0 Anonymous, 780 Guests (See full list)
