Hey, thanks for checking out my topic 1st of all, 2ndly ... as you can see in the "topic description" im trying to find out what a "Daisy Chain connection" is between two amplifiers. If anyone knows what it is please tell, and if possible describe how to link the amps in this fashion.
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
when you've got multiple amps for your substage, you may want to be able to control all of them at once and have them do the same thing - like when you turn the bass knob up you want it to apply to all of the amps.
maxilink (SP?) i think does this, there are other methods also. I'm not an expert in this area- hopefully someone else will chime in
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
Some amps have RCA inputs and RCA outputs you run RCA's from one output of an amp to the others input and so on that's a daisy chain
The master amp gets the input from the deck
Edited by Team Bassick (ALPINE)
yup thanks TB Alpine :)
~Matthew
I've had as many as 8 daisy chained.
I would at least use a line driver to help bump up the rca voltage.
daisy chain is using the rca inputs and outputs on amps. this is NOT strapping the amps, where both amps do the same thing. when daisy chaining, i'm pretty sure you have to set each gain individually and control each amp individually.
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
Yes this is true setting the gains on both amps is called line matching
When strapping amps this step also has to be taken unless you run rf that's the only company that I know of that the master amp sets the slave amps
Daisy chain = linking amps
Strapping = making to amps into one huge amp
did you relay all the remote turn-on's? on some amps i've been able to 'daisy chain' the remote turn-on's for up to 4 amps.....any more none of them would turn on, had to toss a relay or three in the mix.
((((((((((((((((((((((((((((((((((((((((((((((((((((in stereo)))))))))))))))))))))))))))))))))))))))))))))))))))
team audio thugz uuUhhHhhHhh. straight ghanxstuh since 2007.
