ok i cant get winisd alpha to work...but how does this sound...2 4x6" aero ports? would that get me into the 35-40 hz tuning range?
wtf?
they make oval aeroports? :01nocomment8so:
If you are really unsure of port dimensions, then you should stick close to what the sub manufacturer recommends.
PVC works fine for ports if your client is not a perfectionist, they also can be painted. I used to use bondo to attach them to the MDF.
When you decide on the port dimension in square port, there are converters on the internet that help you convert a square port to a round.
If you are not sure on round ports, talk them into a slot port, easier to build and you already have experience with your box.
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
i thought about slot port, but then i thought aero ports would prolly look better if i ported it through the rear deck...ill keep searching and see what i can find
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
box will be aroudn 2 cubes
25 wide
16 tall
9 deep
i wanna port it through the back deck of a 04 civic ex, and want it in between 35-40hz...what do you reccomend? what width and what length??
thank you very much for your help
Are those dimensions you PMed me correct? Are they external or internal dimensions? For a single Kicker Comp 12" I recommend using only one 4" port. Thats a low power sub and won't be moving a ton of air. I'm guessing you'll only be using around 150watts for this sub. For a 2ft net box a single 4" port needs to be 12" long for a tuning of 35hz and 8 5/8" for a tuning of 40hz. The tuning frequency is up to you and your listening preference.
Now if you're set on using two 4" ports then they'll need to be 25 3/4" long for a tuning of 35hz and 19 1/4" long for a tuning of 40hz. Keep in mind that the 4" Precision Ports are only 17" long.
There is some good info here as well as a port calculator.
http://www.psp-inc.com/
thank you for everything!!!!!!! those are external dimensions, yea, he is only giving it around 175 watts daily, its a shity amp so it may be even less...i think ill stick with the one port and start at 12 long and cut an inch as i see sound goes...can i use just a simple 4" wide pvc pipe? it may not look as good, but i can always spray some extra fleckstone i have on it
My F-150 Build
