Ill Hit A 140db
Posted Image only two 12's 1st in my class :search:
2003 Grand AM GTELECTRICAL SYSTEMAlternatorstockBatteryFront s3400back d3100Wireinglots of 0gaHEAD UNITpionner 7500xSPEAKERS(4)Prv 6mb200(2)prv 10mr1000AMPLIFIRLS(1)Zxi80.4(2)Brx1200.4SUBWOOFER(2) MTX 9500BOX3.41 cuft 63sq port 34hzLINKSYoutube.com/reggieb198895
Nice job, good score.
I did the same with my 2 12" LVL 3 12's a while back. well a 141.2 at 46 HZ, in my regular cab Dodge Ram haha.
Nice score though!
2000 Ford Explorer XLT
-20" RVM "Buck" Wheels
-2.5% Tint
-CompuStar Vizion Alarm
-(4) Infinity Kappa 680.7cs 5x7"
-1 XStatic BatCap Model 300
-2 18" DC LVL 4's
-Amps are undecided
i want my next step to be i 150.0DB:D
nice score what you plan on using to hit a 150 cause thats what i working on now in my 02 civic and have been trying to get there for a while. I had to Kicker L7's on 3000 watts through into the car sealed off from the trunk and hit a 147.1 so I changed to a 18" Solo X on 4000 watts and only hit a 146.7 in a wall which pissed me off I think it was tunned alittle low though for spl. Now Im switching to 8 10" on 4000 watts in a wall so i better hit my mark now if not more than that.
By the look of that wave yo must have turned the volume up pretty high :)
1992 GMC Sonoma
2008 MECA S1 Champ, 2010 MECA S2 Champ
Going from 140 to 145 is harder than 0-140 in terms of time put in unless you get lucky and find a sweet loading spot and gain a quick few dB. Every dB over 145 is tricky, every dB over 148 is a bastard, every dB over 150 is GOLD.
This applies to Street class SPL, mind you.
Remember that 3dB requires a doubling in pressure so you need a bit over 3 doubles... that's 8 times the pressue ;)
Try burping it a little longer next time. From that photo it looks like you only gave it a real quick blip, give the wave time to build in the car.
Looked clean though, good start :)
10.x volts fo' life!
to go with me 150db im lookin at the 8000 watts champion series
grats bro...my first dakota did a 141.2 with 2 12s and 600 watts.
gonna need a LOT to break that 150 barrier
NoFearX18 said:
trainman0978 said:
well i'm trying for 150db aswell at 148 at the mo but the batterys were down at 12volt with the engine on and standard altinator so once thats sorted we will see.
Using 2 sealed L5 12" and a solo x 18" ported all in a wall the solo x is gettin 2500 and the l5s 1000
I bet if you lose that retarded idea of adding those l5's in and just make a wall for the solo x and use the other amps and strap them to the solo x you could hit just as high if not higher.
Car Audio + Bodyboarding/Longboarding = LIFE!!!
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
