Sounds like a similar problem to what beatitouttheframe was having.  Read through this post and see if it doesn't help any  http://www.stevemeadedesigns.com/forums/in...hp?topic=2596.0
very similar to his problem...
when i start my car... starts up fine... when the car finally warms up.. it shakes pretty hard "as if it was idleing too low"... "as if it didn't have enough oil"... well... when i gas it.. the car has a delay... like when i floor it... about 2--4 seconds later it will jump like crazy and then idle off or just die... i can't find a damn local show with a o2 sensor so i can adjust it... and the car's power is very weak... and... when i slowly gas it... it shakes like its about to shut down "sometimes it will... sometimes it won't"... any ideas or suggestions or questions to the answer ?
BTW my car is a 425 7.0L V8 and the carb is a elderbrok (sP?) 700 and my friend just put it on.. but doesn't know how to adjust it correctly.. FTL..
ever think about paying the 80 dollars diagnostica dealership charges and going from there?
your looking for a 02 sensor?  maybe you have your terminology messed up.  look into a chilton or haynes manual bro
more likely... but its the air/fuel ratio to set the carb just right... u know ?  :watsup: :tongue:
If you stomp on the gas and have a delay before anything happens, more than likely your carb is set way to rich.
2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
Yes rich being too much gas. And if you found a Chevy dealership...they should work on anything ever made by GM...including Cadillacs.
:sick: :sick: :sick: :sick: .....that's just wrong man. You never ever trade in an american classic for an import. Even if the caddy is old, nothing special, runs bad, and way too big for most folks to drive.
my toyota was built in the USA, by americans! but you are correct that cadi is an american classic and i would never hate on the good ol US of A!
Barretto MotorsportsTeam RFCTeam CHMTeam SMD "Blow Sand"Live Your Life Without Boundaries... http://www.jeffbarretto.acnrep.com/d_oppor...A=US_EN&BW=
  • Who's Online   0 Members, 0 Anonymous, 2084 Guests (See full list)
