I wanna know how do you repair a speaker? Like disassemble it and reassemble it.
THE GRADUATE 10:18:2007
1) a spinning turn table you can use to lay down perfect beads  of glue on the speaker
2) proper epoxy (some people like CA cuz it dries fast) and rubber based glue for surround/dome (Ive used black engine RTV and works damn good)
3) shims to pefectly center the coil, gap the coil from the pole piece/ top plate -If you have calipers which is a must have, you should have shims that are .010" 0.020" 0.030"
047_47.JPG_thumb
048_48.JPG_thumb
049_49.JPG_thumb
So, I can basically repair any speaker that I have? Cuz I have an old pair of JBL Power GT series GT102 10's that I wanted to fix.
Specs: Single 4-ohm
          Nom. Pwr: 130W
          Peak Pwr: 260W
          Sens.: 94 dB
          Mag. weight:40 oz
          2" single voice coil
Probelm: One of them sounds like something keeps bouncing around in the dustcap. That shit just irrates the hell out of me. And I want to fix it.
What kind of tools will I need to fix it? It doesn't have any screws on it to take apart. How do I go about fixing the sub?
i seriosly doubt your going to be able to get a recone at this point but you can get someone to make one for you... i knwo fi has done a few oddball recones
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
ive seen RE recones from them (i would hope they could do RE ones,) and I've seen 1 set of Ascendant recones
sorry there was a 5hr delay between posts, I had to drive daughter for school orientation for second semester. I posted more pics, but I guess I logged off before they finished uploading. But unless you contact JBL tech support, finding recones for those speakers will be damn near impossible... If you did recone them, outside JBL, the specs will be all off. Cone weight, surround desity, cone Fs, and Spider Fs/newtons, vc weight, winding width, wire gauge, former type will be all off.
But for speaker tear down, you will need a nice clean box cutter.
-alch or acetone, shop towels, double sided tape popsicle/coffee stirrer sticks- all for cleaning the motor, No dirt or debris can be in the VC/magnet gap A plastic caliper with digital display, and a height pin on the caliper, so you can measure the VC proper height setting
Got to ruff up all glue surfaces for best glue bondage
BTW, if anyone wants any, I have about 30- 10" carbon fiber speaker cones, rubber surround 2" vc opening, and about  225 12" Carbon fiber/rubber surround cones for sale
:whistling:
:whistling:
Damn that's a lot of repairing. I think I'll just stick with these and find a way to get fixed. But thanks anyway.
  • Who's Online   0 Members, 0 Anonymous, 883 Guests (See full list)
