Ive been wondering, how you get a good lean kick pedal out of a system. every system ive listened to around my part has a nasty heave pedal with a bad overtone...so rock sounds like pure shit. do you think a epicenter would lean it up? maybe the HU preouts are just not clean? ive tryed to find this in another thread but i cant find it, maybe i didnt look hard ebough
Team Deadly Hertz
1997 GMC 1500
Update....
System is gone
Motor is fucked
Truck is down and out for a while
Myspace
YOUTUBE
My Build
a epicenter would defenetly work...or a equilizer too...the RCA's aint the problem...maybe is your HU..i might be wrong..what HU do you have right now?
o yeah and 1 more thing..maybe the pre out's voltage isnt good enough..a good sound quality would be 4 or more voltage pre out's...
It's a shot in the dark, but what about re-tuning the box?
and use efficiant subs(edit... not subs but woofers) with a powerful amp running at 4ohm for less power cunsumption and no distortion. i know other peple are getting results other ways but this is just my sq suggestion
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
Not sure "how you get a good lean kick pedal out of a system" but maybe try a sealed box to get good sounding "heave pedal.''
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
oh well i ahve a jensen 9512, its preamps blow that may be most of my problem then, so ill look into a epicenter or somthing. and the box is tuned a lil wrong, but its happened in more than one box/woofer combo..
Team Deadly Hertz
1997 GMC 1500
Update....
System is gone
Motor is fucked
Myspace
YOUTUBE
My Build
Epicenter won't likely help.
It makes "more" low end bass than is present in the recorded material, which is more taxing on a woofers suspension and performance, so while an epicenter or epic indash unit WILL make it louder and LOWER it will NOT make it "cleaner"...if anything it will have the opposite effect.
For "better" SQ, move from ported to a sealed enclosure, downgrade on power-use...select a more efficient woofer as jack mentioned but with that keep in mind you won't need a mega-watt to run it...although HEADROOM (having more power on tap than you need-or running your amp at a higher impedence-like 4 ohm vs. 1ohm or 2ohm-should produce cleaner signal and better SQ).
I run 4-12's sealed and they have excellent SQ but I can sure "loud and dirty' em up with my epic 160 and most folks say they hit like 15's that way.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
loose the jensen and epicinter is not the sollution its a bandaid. suggestion go to a music store and look at the ttypys of loud speafers used for rock reproduction and then look at the speakers used for car audio there are distinct differences. different types of spekers are better for specific ranges of the bandwidth. so decide what you listen to the most and build your system around thayt
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
Oo, but do you think taht maybe the preamp still does have somthing to do with it, cuz the bass is always muddy anyways...the HU itself only has one sub out, im splitting that to two going to the amp...and thats only a 2v preout. making it one per side...would that have anything to do with it?( how does mr meade have those btls in chickens caddy doing so well on rock?)
Edited by bassbaker15
Team Deadly Hertz
1997 GMC 1500
Update....
System is gone
Motor is fucked
Myspace
YOUTUBE
My Build
