Guest aseanj52 Posted July 27, 2008 Report Share Posted July 27, 2008 I was reading the birthsheet on one yesterday at a shop in Gonzales.....is said.... 2343 At 2Ohm......but......2145 at 1 ohm...... If this is true i am going to look int getting one for my L7's. Dual 2 ohm subs....so either .5 or 2......idk really. lol Link to comment Share on other sites More sharing options...
droopy89 Posted July 27, 2008 Report Share Posted July 27, 2008 Are you sure it maybe didnt say 1343 at 2 ohms? 1997 S10 EC Whats in it 106.9 Sq.ft. Hushmat DB Elec. 250 amp alt. HC800&HC1400 MLA Module Alpine 9886 Knukonceptz wires Clarion EQS746 poopy Alpine door co-ax's Change IS Coming Link to comment Share on other sites More sharing options...
Guest aseanj52 Posted July 27, 2008 Report Share Posted July 27, 2008 Are you sure it maybe didnt say 1343 at 2 ohms?I am 100% sure it said 2343......i will go take a picture tomorrow of the birthsheet...I was so confused.....and still am Link to comment Share on other sites More sharing options...
dmanson Posted July 27, 2008 Report Share Posted July 27, 2008 i've seen multiple people post on having some of the RF power amps putting out more watts at 2 ohm vs 1. i don't know how that works but it's nothing new. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module Link to comment Share on other sites More sharing options...
may03LT Posted July 28, 2008 Report Share Posted July 28, 2008 i have 2 T2Ks, they both make a little more power at 2 ohms i had my dual 2 ohm L7s on one at 2 ohms for almost a year, no problems Link to comment Share on other sites More sharing options...
bass lover Posted July 28, 2008 Report Share Posted July 28, 2008 That's so wierd. Aren't the T1000BD's more under-rated? Link to comment Share on other sites More sharing options...
audiofanaticz Posted July 28, 2008 Report Share Posted July 28, 2008 The amps effiency rating is proboly way higher at 2 ohms compaired to 1 ohm. But it still dont really make sense since rated power at 2 ohms is 1500rms, so for it to be doing almost 800rms more then rated power, you would think that it should do well more then 200 watts above rated power at 1 ohm. Link to comment Share on other sites More sharing options...
audiofanaticz Posted July 28, 2008 Report Share Posted July 28, 2008 That's so wierd. Aren't the T1000BD's more under-rated? yes they are, around 1400-1500 rms @ 1 ohm. Ive seen mine pull around 2000 tho, but that was with a lower then recommended load, and signifigantly higher voltage. Link to comment Share on other sites More sharing options...
ISO Posted July 28, 2008 Report Share Posted July 28, 2008 Rockford has stated that there was a run of T20001BDs that were making equall to more power at 2 ohm instead of 1 ohm. I was under the impression that RF had corrected this issue but I guess not. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
Eric B Posted July 28, 2008 Report Share Posted July 28, 2008 Rockford has stated that there was a run of T20001BDs that were making equall to more power at 2 ohm instead of 1 ohm. I was under the impression that RF had corrected this issue but I guess not. And yall didnt believe me when I said this a few months back.... 2007 Chevy HHR LT UNDER CONSTRUCTION 1st Place Loud N Low 2010 MWSPL Finals 3rd Place Xtreme 3 2010 MWSPL Finals Link to comment Share on other sites More sharing options...
