Posted (edited)
I got my DMM all ready to go to set the output voltage (AC) to 34 for ~1200 wRMS @ 1 ohm ....
The tutorial in the amp section here says to unhook the subwoofer and hook the DMM up right to the amp - and play a 50HZ test tone.
Now, is this bad for the amp? To play music with no sub attatched? please advise
Thanks
Edited by Bass4Lyfe
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
Not at all. while testing its refered to as being unloaded. One of the many steps to getting a clean unclipped signal while setting up with an O-scope.
Scientia est Vox
SMD SUPER BUYER/SELLER
just make sure the pos and neg of the speaker wire isnt touching anything or each other.
Assman Idustries
Fear The Duck
Team Notoriously Loud Mafia
oooh good point Randy. I would just make sure to disconnect the speaker wire from the amp all together to save you from that issue!
Scientia est Vox
Got the amp in today, i'm going to hook it up around 9 am tomorrow. will take pics! allll wires ran everything is ready ....
I'm about to make a enw thread with some questions :)
~Matthew
You know, I thought it was perfectly safe too....
...then 32 transistors turned to ash. Make it quick, your amplifier will love it. Make it long, well, your amplifier may or may not turn into fried circuit board platter. Depends on your protection circuitry. Mine wasn't even there (gooood QC on that one.)
Cheers,
Mick
Work;
DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS Venice
Meyer Sound CQ-1's, CQ-2's, PSW-2's
RAMSA Monitor Amplifiers
P.Audio Monitors
BSS OMNIDRIVE and Soundweb
DBX 231 and Klark Teknik DN360 EQ's
RCF TT22A
RCF ART320
Update:
OKay so I set the gains Wed morning. 34.0 volts AC, it was about 1/4 gain maybe less.
I have since turned it up to just under 1/2 gains because I wanted it louder. I put an Amp-meter (uses the magnetic B field so you just put it aruond your power wire) and its taking in approx. 80 amps at almost full tilt (as fult tilt as i go with my voltage which isn't anywhere near actual full tilt)
its 84% effecient (My T1K) so that means its about 7-800 watts output at 1 ohm, 12-12.5 volts.
My question is - the T1k has a birth sheet at 1600 watts. If I wanted closer to 1400 wats versus the 7-800 i'm getting now, do I turnt he gain up to more like 3/4?
I DON'T want to clip the amp but w/o an o scope how do i tell?
hope this all made sense!
Thx
~Matthew
Cheers,
Mick
ditto. some amps do not like it at all!
When i did my big amps, I had the test tone on pause with my remote in the trunk with me, I could hear the note being played through my amps circuits with no speakers attached, I didnt like it one bit and drove to a shop with a scope 30 minutes away.
  • Who's Online   0 Members, 1 Anonymous (See full list)
