Can someone just humor me and tell me if I should be ok?
Zx1000.1 with 1/0...gain is at half and bass boost is at 0 (all the way down)
Pioneer 5900IB with bass-0
SLA-0
Loudness-Off
HPF-80hz
15" Q
2.6 cubes Internal sealed
2003 Chevy Trailblazer LTZ
Pioneer 980BT
16 SA-10's - 4th Order Bandpass
NS-1 - 3 D3100's
DC & XS Power, Audio Technix, Sound Deadener Showdown
Team Sundown Audio
should be a lpf on 80hz. Anyways what headunit?
DC.jpgDC POWER
what are you running the sub at, final ohms, and where is the gain set at right now?
there are a few different ways to set gains, there is the professional way with a volt meter, or oscilliscope, or the average user way, where you use your ears listen for distortion, then back down some
the deck is listed...the sub is at 2ohms and the gain is half, no bass boost
Pioneer 980BT
NS-1 - 3 D3100's
Team Sundown Audio
the frequency option is only HPF on the unit, unless u can tell me how to change that? lol
Pioneer 980BT
NS-1 - 3 D3100's
Team Sundown Audio
Iam sure your more than fine
could i increase it all? i mean to the best of ur knowledge according to the information i have provided? not the gains persay but the boost up to maybe the first notch or 2? just want to get the most out of it and my DMM just blew and money tighter than a virgin right now so.
Pioneer 980BT
NS-1 - 3 D3100's
Team Sundown Audio
its all in your system man its hard to tell you without being there if you can go any higher. i would just go as high as it will go without distortion then bump it down a notch so you dont have to worry about clipping.
2 18'' fi btls fully loaded
2 sundown saz 3000d
1 iraggi 200 amp alt
3 powermaster 3100d series batts
11.75 cuft wall after displacement tuned to 31.08 hz
the range on the kicker is 250mv to 10v and you hu is listed at 4. I would not go past 1/2.
DC.jpgDC POWER
