03 Silverado Singlecab 4x4 First Fiberglass Enclosure
Forgot the last picture. I did a little sanding before calling it a night to knock off all the fuzz and crap.
Posted Image
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
looks good man. you shouldve worn long sleeves or put baby powder on the deal with the itching. what oz. fiberglass did you use? and about the milkshake (ive never done it), they said it spreads out easier/smoother and its easier to sand. so i would go with that instead of just bondo.
looks nice man it looks like uve been doin this for a while
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
Thanks man, I'm doin the best I can, and half assing projects just don't fly for me. :)
Oh damn, I forgot about the baby powder! Isn't it supposed to clog your pores so the glass doesn't get in? I'll be sanding alot tomorrow I'm definitely going to do just that! Long sleeves just don't fly during august here in TX.
Hmm, so milkshake over the straight bondo then? If it's easier and better in the end then that's the way I'll be going for sure.
Thanks again!
Proud DC owner
Thanks man, but nah, I've just been doing this since the beginning of the thread. From what I've gathered from fiberglassing it's not that it's hard, it's just that it's ALOT of work.
You've gotta be fast AND precise all at once, I guess that's just where the difficulty is.
Anyway, that's just my thoughts on fiberglassing now that I've had my share of experience. :)
Proud DC owner
yeah it is alot of work. layer after layer after layer! Great work so far. cant wait to see how it turns out. :clapping:
4 - 15in Lanzar 2000watt subs
2 Crunch p1500 amps
JVC KD-AVX2 headunit
2 Flipdown 7 in. sunvisor moniters
1 93 Ford Ranger
Finally done glassing! I've got 5 layers technically, but the last 2 were VERY thick with mat.
Quick question though, I see alot of you guys use the milkshake instead of just bondo to do filling. Is there any major advantage or should I just stick with simple and go with just the bondo?
As far as the milkshake-
You basically just wanna add about 20%-40% resin to your bondo/filler mix, then add herdener (the filler hardener (red) is most important but you can add resin hardner too..but I usually do without resin hardener unless it's pretty cold out). By adding a "liquid" (resin) to the bondo/filler mix, you will make the overall mixture more "liquid" and it will "find it's own level"...this will allow more of the air bubbles/pockets trapped within to move to the surface and pop...leaving you with an overall smoother surface b4 you start sanding. The mixture won't "obscure" imperfections as well as it will be thinner than pure filler but it will mean less sanding as long as you have minimized the hig/low spots already.
Lookin nice and solid thus far...I see lots of potential for a great looking/sounding setup here.
Keep it up.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
Keep it up.
Yeah, I have been keeping on top of my layers with my sander so it's been pretty good in my opinion. I did a pretty damn thorough sanding right before the milkeshake so I think I'm going to be pretty good when it's all done!
Thanks loads man, I saw your reply and the other guys in that thread in the other sub forum, you guys saved me big time.
Proud DC owner
Did the milkshake today! :)
Freebies! Found this stuff in the garage that dad had. (I tested it this time to make sure it wasn't more stale stuff, lol)
Posted Image
Posted Image
Posted Image
Posted Image
Did VERY little sanding just to see how well the milkshake worked. I must say I'm pretty happy with the results!
Tomorrow is SANDING, and more SANDING!!! :clapping:
Quick question guys, when it comes to painting could I get a gorgeous gloss finish from just can spray paint? Otherwise what would yall recommend that's decently priced?
Proud DC owner
i say do the textured stuff and make it have the factory finish to match the rest of the interior pieces that are plastic.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
