Not sure if it varies from vehicle to vehicle, but what do PCMs/ECM's handle before they get fried from use of to many volts?
Like would 14.4-15V fry a PCM?
Derp.
As far as I know. No.
I have peaked mine at 15.6v before and it still runs.
Although it is a little older.
Little older? your talking about the Bronco in your signature right?
Like my car, has an externally regulated alt. pre-set at all RPM's and whatever.
Would to many amps from an alt. kill it?
Derp.
Yes the Bronco II, same as a Ranger.
Amps? No.
It's REGULATED so if your battery is getting full, it will back off.
Volts.
I'm pretty sure 16+ would kill something.
Amps? No.
Volts.
X2...the closer you get to 20V, the more problems you ask for
Amps? No.
Volts.
Ahh, I see...
So even though it is externally regulated by the PCM, a H.O. Alt. couldn't hurt anything?
Derp.
Ahh, I see...
No.
Don't quote me on that though.
If the alternator is made for your vehicle, I'm pretty sure they had the regulator in mind and worked with it.
Worse comes to worse, hit up MLA, see if they can help you out.
No.
Okay, well thanks for offering the advice. :)
Derp.
i had a 07 trailblazer loaner car and it would get to about 15.3 on a cold startup
DC.jpgDC POWER
You will be fine at 14.9, but anything higher than that and the battery will start getting cooked if it's an AGM type. 15.5 is OK if it is a flooded battery.
A High Output alternator will not hurt anything as long as the voltage is set within those peramiters.
  • Who's Online   0 Members, 0 Anonymous, 993 Guests (See full list)
