I used a formula from the carstereo.com site to come up with the 5x10 port area, but 5x10 is not the only variation that one could go with.
If you are talking about this design:3woofer.jpg
Then I was going by 45in wide 18in tall and 40in deep so that you can create the pyramid look on the top of the box.
The port on this box was by the size in the original post, but, later experimented with another formula and found out that winISD is not as good of a formula for determining port size, since it only measure the optimum volume and not the volume you want.
Edited by quakecitystudio
Bass Music Producer • Photographer • Graphic Designer
Deep Sector Boom...
It seems that box is around 18 cu ft (40' x 45' x 18'=32400"^3/1728 is 18.75'^3 right?)before displacements so it would have to be smaller. Preferably in the depth I'm hoping to be around 20-22 inches or so. I don't have to have the subs in triangle formation ,they can go straight across the top and that would be fine with me. So I'm planning on using a 12 wide by 7 tall port opening so what should the depth be? I don't know how to figure that part. Still aiming for somewhere between 30-35 Hz.
ive done installs for my buddies with the type rs and i believe i did two cubesish and 25 sq for port area. its in an 03 explorer and has a brutus1606 for power and it beats pretty good actually.
just looked it was 2 cubes 20 per.
Edited by n8ball2013
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Say for example:
45wide 18 tall and 18 depth= 7.3588 ft cubed before port and woofer displacement
and 6.79734 with the port displacement.
1 slot port at 35 hz
and the port being 12 wide and 7 tall.
The length based on the vent length calculator:http://www.carstereo.com/help/Articles.cfm?id=31
would be 11.55 inches deep.
Deep Sector Boom...
check and be sure that you do not have any clearance issues:
Depth of woofer when installed + thickness of wood used + port height + gap between woofer and top of port board.
Deep Sector Boom...
  • Who's Online   0 Members, 0 Anonymous, 887 Guests (See full list)
